Автор Тема: structure  (Прочитано 17805 раз)
Оффлайн abdullahАвтор темы
structure
« : 23 Февраль 2011, 14:04:26 »
I want your suggestions for the implementation of this form (structure)
Re: structure
« Ответ #1 : 23 Февраль 2011, 14:41:12 »
Abdullah today we have a military celebration, chief General
forbade work, relax.
Re: structure
« Ответ #2 : 23 Февраль 2011, 16:13:12 »
abdullah
As I understand it, the problem is how to consolidate the profile to obtyanut PVC film designed inside and out?
How to assemble the very design you already know?
Re: structure
« Ответ #3 : 23 Февраль 2011, 16:31:20 »
abdullah
I suggest you the option to mount the profile of suspended ceilings on a ready-made design
Re: structure
« Ответ #4 : 23 Февраль 2011, 17:01:26 »
abdullah
PVC film need to solder a pipe (stocking)
Re: structure
« Ответ #5 : 24 Февраль 2011, 18:37:12 »
abdullah
is this oky
Re: structure
« Ответ #6 : 24 Февраль 2011, 18:42:32 »
abdullah
is this oky
Re: structure
« Ответ #7 : 24 Февраль 2011, 18:57:03 »
abdullah
This is a good option. You need to pull the PVC film outside only?
Then it is not clear what the problem is
Re: structure
« Ответ #8 : 24 Февраль 2011, 19:23:56 »
abdullah
the problem is :
1- pvc is printing
2- Bending in the middle
Re: structure
« Ответ #9 : 24 Февраль 2011, 19:37:13 »
Understandable.
Make the design more convex outward (or flat/smooth), wrap it Foam rubber*  and then the PVC film will not bend inwards
« Последнее редактирование: 24 Февраль 2011, 19:43:50 от kazah_t »
Re: structure
« Ответ #10 : 24 Февраль 2011, 19:46:05 »
Understandable.
Are there any pictures showing more
Re: structure
« Ответ #11 : 24 Февраль 2011, 19:48:00 »
1 Do not understand the material gives the form?
2 technology attachment?
Re: structure
« Ответ #12 : 24 Февраль 2011, 19:51:41 »
Understandable.
But to be a foam with the same external shape
Re: structure
« Ответ #13 : 24 Февраль 2011, 19:53:59 »
Understandable.
Transparent pvc , there is lighting inside, when you put the foam will obscure the light
Re: structure
« Ответ #14 : 24 Февраль 2011, 20:08:39 »
Sorry, this is a problem, just get a curved structure, too much height
Could it be done?
Re: structure
« Ответ #15 : 24 Февраль 2011, 20:28:30 »
You can do even such a structure. Too beautiful structure
Re: structure
« Ответ #16 : 24 Февраль 2011, 20:43:11 »
Abdullah
You will accept a concave surface? (Picture 14 or 335)
Re: structure
« Ответ #17 : 24 Февраль 2011, 20:46:35 »
Александр62
Ему нужно идеально ровно, чтоб не утянуло пленку внутрь, на высоте конуса в 3,2м...еще и обтянуть транспарентом с печатью и подсветкой изнутри
Re: structure
« Ответ #18 : 24 Февраль 2011, 20:52:07 »
Александр62
Нереально. Надо дать ему исполнимый вариант с подсветкой. К этому и подвожу.
Re: structure
« Ответ #19 : 24 Февраль 2011, 20:56:11 »
Александр62
вот и я выставил возможные фото исполнения (нужно делить, высота большая)...но варик с утянутой линзой пленкой ему ни как не нравится
Re: structure
« Ответ #20 : 24 Февраль 2011, 21:00:11 »
Александр62
Is it possible to reduce shrinkage, to get less Bending
Re: structure
« Ответ #21 : 24 Февраль 2011, 21:06:50 »
The bend size can't be counted. It is possible to be trained on small models and to understand, how the bend will look in a reality.
Re: structure
« Ответ #22 : 24 Февраль 2011, 21:08:42 »
I think not ... a great height ...
Canvas on a figure for the ideal forms, it is necessary to divide
Re: structure
« Ответ #23 : 24 Февраль 2011, 22:16:32 »
Так как он хочет только на ткань.
Re: structure
« Ответ #24 : 24 Февраль 2011, 22:25:32 »
а это идея...есть ткань транспарентная же? и кто возьмется обьяснить?
